Tlr125 Taper Bearings
bashplate
i gather the honda number for the taper KIT is SSH200, which also fits XL75-185 and XR200 twin shock. still not got an actual bearing number though that we can take to the bearing supplier.......best tell the lazy sh*t to take his forks to bits so we can measure the shaft and pocket size which will enable us to look at the size charts.
  • 1 month later...
Hi, slightly off topic,but I am trying to rebuild a Dax, and want to replace the steering head bearings. I cannot see what holds the taper roller bearings in place,ie pulling together in the headstock tube. I did this job on a BSA Otter but that had sockets for the bearings to sit in. I will also change the bearings on my TLR200 if it works OK on the Dax. Anyone like to comment?
