Beta Evo 4T Brake/clutch Fluids Amount?
trialholic
Hi
I want to change brakes (front and rear) and clutch fluid in a Evo 300 4T and I need to know roughly how much amount of fluid will I need.
I want to try MOTUL RBF 600 wich comes in 500ml bottles, so how many bottles should I order, 1, 2?
Thanks
One is enough to do a couple of bikes!
I use a long piece (1.5m) of clear plastic tube over the nipple.
Attach to the nipple to bleed and use a rubber band to attach it to the handlebars. You now have a system where air cant get in and you can see the fluid coming through.
Suck out the master cylinder and fill with new fluid.
Bleed as per normal.
I find that once the pipe is filled up during bleeding it is enough to bleed through air, dirty fluid and new fluid (you will see a colour change).
