Pink Oil
jezinlaneham
Hi Jez & Henry Yes you have water in the oil, most likely the water pump seal has gone, easy to fix, remove pump, fit new seal, be careful not to pinch the pump ( this happens if you push the seal too far in ), top up, change oil, happy days :banana:
Regards Bob
Regards Bob
Brilliant and thanks for taking the time to respond
