jezinlaneham Posted April 11, 2012 Report Share Posted April 11, 2012 My son owns a gas gas 2004 txt pro; the oil started to leak and also it was pink!! Other riders thought water in the oil? Is this a disaster or simple to remedy? Thanks for your help Jez and Henry Quote Link to comment Share on other sites More sharing options...
oxboy Posted April 11, 2012 Report Share Posted April 11, 2012 Hi Jez & Henry Yes you have water in the oil, most likely the water pump seal has gone, easy to fix, remove pump, fit new seal, be careful not to pinch the pump ( this happens if you push the seal too far in ), top up, change oil, happy days Regards Bob Quote Link to comment Share on other sites More sharing options...
jezinlaneham Posted April 11, 2012 Author Report Share Posted April 11, 2012 On 4/11/2012 at 10:01 AM, OXBOY said: Hi Jez & Henry Yes you have water in the oil, most likely the water pump seal has gone, easy to fix, remove pump, fit new seal, be careful not to pinch the pump ( this happens if you push the seal too far in ), top up, change oil, happy days Regards Bob Brilliant and thanks for taking the time to respond Quote Link to comment Share on other sites More sharing options...
tltel Posted April 11, 2012 Report Share Posted April 11, 2012 Or its ATF in the engine! TLTEL. Quote Link to comment Share on other sites More sharing options...
oxboy Posted April 12, 2012 Report Share Posted April 12, 2012 Hi Jez & Henry Forgot to mention theres a useful video on Utube on how to change the seal, it will help if you have not done this job before Bob Quote Link to comment Share on other sites More sharing options...
