dixie Posted April 11, 2012 Report Share Posted April 11, 2012 Hello old chap, as you saw i knocked my kickstart off on Exmoor 2 day , cant remember what else you said to change, got a return spring and shaft . is it worth setting a bronze bush in the outer casing, there is quite a bit of free play ?? Hope you enjoyed the trial Quote Link to comment Share on other sites More sharing options...
lee harris Posted April 11, 2012 Report Share Posted April 11, 2012 Hello old chap, as you saw i knocked my kickstart off on Exmoor 2 day , cant remember what else you said to change, got a return spring and shaft . is it worth setting a bronze bush in the outer casing, there is quite a bit of free play ?? Hope you enjoyed the trial Hi Dixie, the trial was great wasnt it. Well done to finish without a kickstart shaft Spring and shaft for sure. Mains, seals and gaskets Go to ebay.de and buy a conrod kit for about 80 quid. Let m know if you need help I have never needed a bush in the cover as the new ks shaft will be without an o- ring groove. Play is not important. What does Bill habe to save? Speak soon L Quote Link to comment Share on other sites More sharing options...
dixie Posted April 12, 2012 Author Report Share Posted April 12, 2012 Just stuffed a tissue in the hole and parked on any slope i could, had some mates so waited with them in the que and popped off for the bike just before my turn, would of burnt it out if i had to keep it running. See you next year , or Dartmoor ?? Quote Link to comment Share on other sites More sharing options...
lee harris Posted April 16, 2012 Report Share Posted April 16, 2012 Dartmoor! Quote Link to comment Share on other sites More sharing options...
