Reflex Sticky Throttle
docrogers
Hey,
Okay, I have an old Reflex with a perpetually sticky throttle. I have cleaned and lubed the cable and the throttle to no avail. My guess is that the cable housing is crimped somewhere and that the fix is a new one. Problems: first, how does one remove the cable from the throttle assembly? Doesn't seem possible to get the ball end through the housing; my guess is that Honda designed it that way. Assuming that, it seems near impossible to get a replacement cable, so what can I do for a replacement throttle cable + housing + tube? Sources? Part #s? Replacements/substitutes?
Hi DocRogers,
have a look here:
http://www.tytrials.co.uk/trailandtrialsuk/cat_154758--17-Levers-Cables.html
http://www.venhill.co.uk/
http://venhillusa.com/
I use a Venhill throttle cable with an Amal T80/200 Twistgrip and a Venhill clutch cable. Gives much smoother and lighter action than Honda cables. Don`t lubricate with oil, better with teflon spray (PTFE).
For front brake I like the more rigid OEM Honda cable.
Rollox
