Ossa Wheel Bearings 2012
jsp
The rear has 2 different bearings, the 6004 is thicker but be carefull the thin 6905 bearing was also in a thin bush which came out as I drifted the bearing out, make sure you dont throw the bush away with the old bearing and refit the bush before you fit the new bearing.
The front wheel bearing change is really easy, knock the inner sleeve between the bearings down then drift the bearings out, to refit I think it's a 32mm socket is the right diameter too knock the bearings in with. Some people flick the bearing covers out and repack the bearing with grease I've tried this but the bearings never lasted any longer so I don't think its worth the hassle. Front bearings can be changed easily within 1/2.
Hope this helps.
Thinking about it I reckon my rear hub was a Friday afternoon one ! it has a sleeve because if was machined over size and has had a repair done on it !
Edited by Taff_d
sounds simple enough, ive always packed the new bearings with grease
when ive done the back ones, and i also do it everytime i have the wheel
out, but never changed the front ones. and i havent changed any on the
ossa. order my new 6905 from ak, i had some 6004 in stock as there the
same as most bikes
jsp
to be honest i dont think mine are doing that bad as
i ve had it since september and this is only my first
set, and it gets ridden at least once a week come
rain or shine, and i m a clean freak !!!
jsp
