bondy Posted April 13, 2012 Report Share Posted April 13, 2012 hello again guys need your help on refiting the gear selector. ive took it off to change the gasket but not sure how it gose back. ive had alook in the manual it says put the bike in neutral? how do i do this now all the bits are off? once in nueutral it says the selector must be properly timed. witch way dose the pawls have to be??? Quote Link to comment Share on other sites More sharing options...
naichuff Posted April 13, 2012 Report Share Posted April 13, 2012 Is the manual talking about the selector drum or the the pawls Fit pawls into slots curved end inward and push agains the springs rotate shaft through 90degrees locking the pawls down Fit the gasket and the pawl assembley Rotate shaft back so the peg is at the top Refit gear peddle shaft with slot engaging the peg Quote Link to comment Share on other sites More sharing options...
bondy Posted April 13, 2012 Author Report Share Posted April 13, 2012 cheers pal ive done it hopfully this new gasket should stop oil geting in the gear box. also fingers crossed should stop the gear oil prewing out the end drive. ive tryed evrrything else. then once thats shorted i can sort the power for some reson there dosant seem to be much power. it was ok before i put it back together am trying a diffrant carb to see if that helps. i put a electrice igntion on from bultaco uk making me think that may be the problem so am thinking going back to points. Quote Link to comment Share on other sites More sharing options...
