mike64 Posted April 16, 2012 Report Share Posted April 16, 2012 I've had an 07 SY250 for over two years now and recently the bite point of the clutch varies when the bike gets warm. When I do a slow speed circle, 1st gear, clutch out, on tick over the bike jerks forward each time the engine fires ' or at least that what it feels like' I know the gear oil needs replacing but is it worth stripping the clutch to check the friction plates first ? If the plates are worn would they give these symptoms ? Or could it be anything else I've overlooked cheers mike Quote Link to comment Share on other sites More sharing options...
stork955 Posted April 17, 2012 Report Share Posted April 17, 2012 Gday, that would be normal for a slow turn. Drag a little rear brake and use a touch of throttle to smooth it out. If there was a clutch problem it would slip. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
godzilla Posted April 18, 2012 Report Share Posted April 18, 2012 (edited) Mine is similar, I fitted a reach adjuster in the lever, sometimes I give it a twiddle. There is also a gods chance the exhaust could do with re packing of something like that, what oil are you running? Some seem to degrade quicker than others. Edited April 18, 2012 by godzilla Quote Link to comment Share on other sites More sharing options...
mike64 Posted April 20, 2012 Author Report Share Posted April 20, 2012 I'm using Motul 5100 , I've been advised to check a few things, chain sprockets etc. Do you still have that heavier flywheel, if so could I try it ? Cheers Quote Link to comment Share on other sites More sharing options...
