md04 Posted April 19, 2012 Report Share Posted April 19, 2012 Hey guys have any of you fabricated a cartridge holding tool for the left fork leg on the 315R if so tell me please coz the proper tool is crazy expensive. thanks Quote Link to comment Share on other sites More sharing options...
hughesy Posted April 19, 2012 Report Share Posted April 19, 2012 You don't need the tool at all, I did both my forks this weekend and once I'd cracked the allen bolt off on the bottom I simply applied pressure to the "nut" using a length of 22mm plastic cable conduit. It wasn't perfect by any means but I did both legs this way without any problems. Quote Link to comment Share on other sites More sharing options...
md04 Posted April 20, 2012 Author Report Share Posted April 20, 2012 (edited) You don't need the tool at all, I did both my forks this weekend and once I'd cracked the allen bolt off on the bottom I simply applied pressure to the "nut" using a length of 22mm plastic cable conduit. It wasn't perfect by any means but I did both legs this way without any problems. thanks for that i might give it a try nothing worse than a leaking seal. Did you manage to get the correct torqe pressure when locking it up? Edited April 20, 2012 by MD04 Quote Link to comment Share on other sites More sharing options...
