Bits In Oil - Beta 80
crashmonkey
Hi, I have just done an oil change on the 80 and notices quite a lot of fine particles in the oil :o
Is there anything in particular that its likely to be?
I'd rather spend a few quid now rather than waiting for it to go pop.
Any pointers would be appreciated as i'm beginning to flap!
Only thing I can think of is that the clutch always sticks when its cold, could it just be from the clutch basket?
cheers
should be fine you dont want clean oil coming out as it means the oil is not doing its job, any way chances are bits of clutch friction plate as it is a trials machine
Edited by benwall
You don't say how long ago the oil was last changed.But It's Probably only clutch friction material if it's dark gray. If it's sparkly metal look deeper. My son's 80 always had a sticky clutch until I followed the advice in the clutch fix post at the top of this forum.After it was lick a totally different bike!
