neilh Posted April 21, 2012 Report Share Posted April 21, 2012 hi. any of you lads know where i can get a big syringe on a sunday? my bike seems to have developed a spongy or near enough not working rear brake (unusual?) no external leaks and the reservoir was full so im not sure how air has got in there? Quote Link to comment Share on other sites More sharing options...
chewy Posted April 21, 2012 Report Share Posted April 21, 2012 chemists shop?..there is usually noe open for prescriptions in a town..I got mine from a chemists. Quote Link to comment Share on other sites More sharing options...
andat Posted April 21, 2012 Report Share Posted April 21, 2012 Got mine from an equine shop...they use em for doping horses . Paid the astonimical sum of £1.95. I tried chemists but with no luck Quote Link to comment Share on other sites More sharing options...
davelewis Posted April 21, 2012 Report Share Posted April 21, 2012 Neil, I have one you can lend. I'm near Cardiff. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted April 21, 2012 Report Share Posted April 21, 2012 Most big stores that sell kitchen supplies have them. Used for injecting flavors into turkeys, etc. Quote Link to comment Share on other sites More sharing options...
toothandnail Posted April 21, 2012 Report Share Posted April 21, 2012 I use the ones that come with a printer ink cartridge refill kit. Quote Link to comment Share on other sites More sharing options...
benspeed888 Posted April 22, 2012 Report Share Posted April 22, 2012 last one i bought came from zoars ark in neath, think it was about a quid Quote Link to comment Share on other sites More sharing options...
benspeed888 Posted April 22, 2012 Report Share Posted April 22, 2012 (edited) think it held about 50 mls if i remember correctly, and yes zoars is open sundays Edited April 22, 2012 by BENSPEED888 Quote Link to comment Share on other sites More sharing options...
neilh Posted April 22, 2012 Author Report Share Posted April 22, 2012 ive got a gunsons eezi bleed kit now guys ill give that a go first. i forgot i had it to be honest. cheers for the help and offers of a lend tho Quote Link to comment Share on other sites More sharing options...
neilh Posted April 22, 2012 Author Report Share Posted April 22, 2012 hi, i done this job an hour ago and it worked like a champ. i took the reservoir off and joined the pipes up and bled it from the bleed nipple. i used air pressure from the front tyre of the bike. you can also use this to bleed it backwards by connecting to the bleed nipple if u wish. here it is for anybody interested : http://www.gunson.co.uk/item.aspx?cat=674&item=1818 they are cheaper than that in halfords, i got mine there years ago Quote Link to comment Share on other sites More sharing options...
neilh Posted May 5, 2012 Author Report Share Posted May 5, 2012 UPDATE on this. No rear brake pressure again... and the bike has not been used since my previous post. kitted up earlier this afternoon to go for a ride and nearly wrote my bike (and myself) off into my garden gates on my way out. i was fed up then so i stripped everything down and found the bleed nipple on the rear caliper not sealing. on removal of the nipple i found that the previous owner or garage that has done work on it has stripped the aluminium threads out of the caliper by overtightening the nipple, and they then inserted a heli-coil into the caliper to try and repair it.. well it didnt. i managed to find a bigger bleed nipple in my box of bits, so im gonna drill it out tomorrow and re-tap a new thread in the caliper if it dont work then its new caliper time. balls. Quote Link to comment Share on other sites More sharing options...
hoggyf Posted May 9, 2012 Report Share Posted May 9, 2012 Bad luck on that one - does the Gunson kit have a cap that replaces your lid on the master cylinder?? never used one and dont want to buy one that doesn't fit my M/C Quote Link to comment Share on other sites More sharing options...
neilh Posted May 9, 2012 Author Report Share Posted May 9, 2012 i had a stroke of good luck to be honest. i managed to fit a new bleed nipple and all seems ok so far. i didnt bother updating as it looked to me like people werent reading. to answer your question, no i have not got a cap that fits. either remove the cap from the eezibleed and connect it to the bleed nipple on the bike to bleed it backwards, or take the pipe off the little reservoir on the bike and join them up then crack the bleed nipple open. it works so good ill never do it any other way now. Quote Link to comment Share on other sites More sharing options...
neilh Posted May 9, 2012 Author Report Share Posted May 9, 2012 oh and while its pressure bleeding, you give the brake lever a cheeky little pump aswell. but only depress the pedal half of its maximum travel, or three quarters at most. never fully down, the seals dont like it Quote Link to comment Share on other sites More sharing options...
