lee99780 Posted April 22, 2012 Report Share Posted April 22, 2012 Hi all, Im having trouble with my clutch, I can pull it in and select gear no problem,, once I release it it doesn't bite until the lever is right out then a second our two and I'm off, once its out its fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 22, 2012 Report Share Posted April 22, 2012 (edited) Watch the piston on the clutch master cylinder. Is it slow coming out? That or the slave side is sticking. Are you using the correct fluid. Mineral oil or dot 4?This also can happen with too much oil in the engine. Edited April 22, 2012 by lineaway Quote Link to comment Share on other sites More sharing options...
lee99780 Posted April 27, 2012 Author Report Share Posted April 27, 2012 Hi, all sorted, put a new seal kit in the slave cylinder, new mineral oil and oil in gearbox if anyone else has this problem!total cost of 19 quid ! Quote Link to comment Share on other sites More sharing options...
