zerorev3rev4 Posted April 22, 2012 Report Share Posted April 22, 2012 (edited) as title its an 2011 seems to get very hot ,popping low power smoking after first lap then ran ok its been going on for some time but cant get to bottom of it fan works, usually when cooled down for couple mins it runs ok again ,also another one on trial today with same symptoms Edited April 22, 2012 by zerorev3rev4 Quote Link to comment Share on other sites More sharing options...
chewy Posted April 22, 2012 Report Share Posted April 22, 2012 I wasted a precious year of my trials life trying to make one of these work.... normally I keep my mouth shut if I.ve nothing good to say but ......best suggestion is to get rid of it. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted April 22, 2012 Author Report Share Posted April 22, 2012 I wasted a precious year of my trials life trying to make one of these work.... normally I keep my mouth shut if I.ve nothing good to say but ......best suggestion is to get rid of it. on the cards Quote Link to comment Share on other sites More sharing options...
copemech Posted April 22, 2012 Report Share Posted April 22, 2012 (edited) I doubt it would be a sheared key on the flywheel as it fixes itself. I would think most likely culprit an ignition coil, next a CDI unit.(providing plug ok) Call Splatshop to send you some parts to swap, you can return what you do not need. Easy peasy! Never mind Chewy, he spent six months trying to make a tire too big stay on the rim! Might also try closing the plug gap down to about .015 just to see if it makes a change, as that would also indicate a weak coil. Edited April 23, 2012 by copemech Quote Link to comment Share on other sites More sharing options...
