davet Posted April 28, 2012 Report Share Posted April 28, 2012 When on tick over nearly cuts out ,i have to rev to stop engine stalling. But when giving it some power the engine does not miss a beat, but as soon as i shut off the engine sounds as though its searcing for more fuel. Never worked on this type of carburettor before, there is only one screw which i belive to be the air screw.The carb on other bike had fuel & air screw. Can anyone give me some guidance on what to do or what to check , Thanks Quote Link to comment Share on other sites More sharing options...
lowbrow Posted April 28, 2012 Report Share Posted April 28, 2012 The larger screw that is angled upwards is the throttle stop. Screwing this in will increase the tickover. The smaller, recessed screw furthest from the motor is the mixture screw. Screwing this in reduces the amount of air mixed with the fuel in the pilot circuit, and vice versa. Provided your jetting hasn't been played with the mixture screw should be about 1.75 turns out, + or - quarter of a turn Quote Link to comment Share on other sites More sharing options...
blocky Posted April 28, 2012 Report Share Posted April 28, 2012 Sounds like the idle jet is blocked Quote Link to comment Share on other sites More sharing options...
davet Posted April 29, 2012 Author Report Share Posted April 29, 2012 (edited) Cheers Blocky which is the idle jet and can it be taken out, without dismantling carb ? Edited April 29, 2012 by davet Quote Link to comment Share on other sites More sharing options...
