scorpa01 Posted April 30, 2012 Report Share Posted April 30, 2012 could do with a little help not for me for a friend as i have the uber reliable scorpa 250 , any way he has bought one off the above 4T ON A 05 it has the kehien carb and the decompression lever and the exhaust heat guard near the carb but this is still proving to be a utter t**t to start hot or cold , have read a few post on them but no one seems to give a good clear answer on how to solve the problem of the starting issue. please could anyone put pics or even replys up for everyone to see even vids of your own running cheers . Quote Link to comment Share on other sites More sharing options...
bobtlr Posted April 30, 2012 Report Share Posted April 30, 2012 (edited) i had a 2007 it didn't start good eater changed the 28mm kehin for a 24mm oko and it was perfect pilot jet 35 main jet 100/105 kind regards bob Edited April 30, 2012 by bobtlr Quote Link to comment Share on other sites More sharing options...
neilnh Posted April 30, 2012 Report Share Posted April 30, 2012 Thought they didn't start making them until 07 Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 30, 2012 Report Share Posted April 30, 2012 Thought they didn't start making them until 07 It was 2005, Not 07. Quote Link to comment Share on other sites More sharing options...
digger144 Posted April 30, 2012 Report Share Posted April 30, 2012 i had the 07 320 i blanked off hot start device, threwaway plug cap &lead fitted old style plug lead & push on car type plug cap starting then was a lot better but you really needed to lean on a tree, get high on the kickstart & give it a good hefty kick.glad to see the back if i am honest which is a shame because it was fun to ride Quote Link to comment Share on other sites More sharing options...
scorpa01 Posted April 30, 2012 Author Report Share Posted April 30, 2012 yeah its a fantastic bike when running cannot fault it just so hard to get going again , but still open to suggestions off anyone all welcome cheers Quote Link to comment Share on other sites More sharing options...
neo Posted May 1, 2012 Report Share Posted May 1, 2012 but still open to suggestions off anyone all welcome cheers Rocket fuel Seriously though .... good luck with that one.... Let us know if you uncover something....You'll make many of owners much happier. Try the OKO 24mm change ... it's a great carb. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 1, 2012 Report Share Posted May 1, 2012 Big bore 4T's can allways be a bit iffy it seems, Bobtlr has indeed raved on the little OKO, and they are inexpensive to boot. I think it was in '08 they refined the Kiehin further with some different internals, and the one I rode seemed good. As long as the decompressor is working, all it took was a steadt methodical prod, possibly easier than a 2.9. Assuring good plug and spark are allways key, and usually the rituals will begin with a couple slow prods with choke engaged just tu get things juiced up, then a real prod with NO throttle, they do not seem to like things when folk inadvertantly crack the throttle tube out of habit as is messes the mix up and things go sour. Finding the ritual specific to a bike can save a lot of effort it seems. Quote Link to comment Share on other sites More sharing options...
bobtlr Posted May 1, 2012 Report Share Posted May 1, 2012 i also fitted bosch super plus yttrium plugs +8 Quote Link to comment Share on other sites More sharing options...
climber Posted May 1, 2012 Report Share Posted May 1, 2012 Starting technic My 3.2 F 2007 always starts very easely. It is a technic with these engines. Do not rush. You have to first let the kickstarter go slowly to the bottom so the piston also gets to bottom position. When cold I always have the choke on. Mine has a 42 pilot and the airmixscrew 360 degrees out from bottom position. Try also 270 degrees out from bottom position. When you press the kickstarter do it even and firm and give throttle when the kickstarter hits the bottom. I do often stand on the bike when I hit the starter. If you do not succed try again in the same manner. Do not rush. Check also the floater hight if this does not helpt. Quote Link to comment Share on other sites More sharing options...
shercoholic Posted May 4, 2012 Report Share Posted May 4, 2012 could do with a little help not for me for a friend as i have the uber reliable scorpa 250 , any way he has bought one off the above 4T ON A 05 it has the kehien carb and the decompression lever and the exhaust heat guard near the carb but this is still proving to be a utter t**t to start hot or cold , have read a few post on them but no one seems to give a good clear answer on how to solve the problem of the starting issue. please could anyone put pics or even replys up for everyone to see even vids of your own running cheers . Hello Scorpa01, Please check your Messenger Conversations for pm. http://www.shercousa.com/pdfs/kickstart.wmv. Quote Link to comment Share on other sites More sharing options...
sherpa Posted May 7, 2012 Report Share Posted May 7, 2012 I have a 3.2 2009, starts fine using the above (Climber) push down slow technique. If the bike has been stalled "hot", the first two rotations should be with the throttle wide open, then closed one kick and she's running. One other thing, my 3.2 does not like to start when pointing down hill. Seems like alot of work to get started, but just like my wife, what a great ride when shes running. Quote Link to comment Share on other sites More sharing options...
