lastplacebrad Posted April 25, 2005 Report Share Posted April 25, 2005 Hi all , i have sold my 03 pro and purchased an 04 SY250 , What g/box oil do i use , how much (it says 700ml on cases) Do they prefer any kind of 2t Where do i need to be with my suspension settings approx as i think a big lad has owned it previously , i only weigh 10 stones drippin wet ! Anything untoward to watch out for ..... cheers , Brad Quote Link to comment Share on other sites More sharing options...
jenkinsm Posted April 25, 2005 Report Share Posted April 25, 2005 Silkolene Light gear box oil will surfice . Seems like you have taken a step backwards on the bike front although im sure you have a good reason for doing so. As for things to watch out for, keep an eye on the front engine mounting bolt which runs through the frame and engine. Prone to snapping but many do not realise it has happened. Unless he has altered it i would only advise you soften it a bit as it will give you less lift or bounce. Also advise that you drill and tap a hole in the bottom of the carb drain bolt. Then run a tube out of it with a plug in the end because if you get water in it at a trial you'll be up ****s creek. Happy Riding m8 Quote Link to comment Share on other sites More sharing options...
dfwilson Posted April 25, 2005 Report Share Posted April 25, 2005 600 ml of synthetic transmission oil is good. I use Mobil 1. If your bike does not have it, buy a flat skid plate. If you ride in a rocky area you might want to get a water pump cover. It Quote Link to comment Share on other sites More sharing options...
jadoca Posted April 25, 2005 Report Share Posted April 25, 2005 sounds like a step forward to me. best of luck with your new bike. regards, Quote Link to comment Share on other sites More sharing options...
lastplacebrad Posted April 25, 2005 Author Report Share Posted April 25, 2005 Thats all gravy , but the damn thing wont start , so i'm taking it for a trip back to the dealer Quote Link to comment Share on other sites More sharing options...
Guest coflet Posted April 25, 2005 Report Share Posted April 25, 2005 What you must bear in mind is the scorpa sy dosnt run on normal petrol it actually runs on diesel, if you want to know anything about scorpas speak tp Bri (scorpamadman) he has totally destroyed a 2004 sy in one year!!!!!!! Quote Link to comment Share on other sites More sharing options...
scorpamadman Posted April 25, 2005 Report Share Posted April 25, 2005 hello feller`s. scorpa`s are ace will be buying another [after this one`s packed in] well done brad about time u had a decent ride. and to pete the bike had been riden thats all[to death] lol....... and the comment about it being diesel. at least mine starts when up camp........lol. cheers Quote Link to comment Share on other sites More sharing options...
boofont Posted April 25, 2005 Report Share Posted April 25, 2005 at least mine starts when up camp........lol. cheers Has it got some kind of sexuality crisis then? Quote Link to comment Share on other sites More sharing options...
Guest coflet Posted April 26, 2005 Report Share Posted April 26, 2005 Hey brad saw your new scorpa today at birdies hes drained the tank and put some fresh diesel in it , it now runs perfectly just like a massey ferguson !!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
