upinthehills Posted May 13, 2012 Report Share Posted May 13, 2012 I am considering fitting a V Mar linkage to the suspension on my 4 RT. Wonder if this has been found by those of you who have already done this to be a worth while upgrade. I do find that the suspension is a little soft. I am still running on the standard shock. If any one has any suggestions as to stiffening up the suspension a little I would be happy to here from them. Cheers Ali Quote Link to comment Share on other sites More sharing options...
highscore Posted May 31, 2012 Report Share Posted May 31, 2012 I put V-Mar plates in my 315, very nice. They just up the leverage ratio a bit so you gain some stiffness. Never a bad thing . I would give the plates a try before spending ££££s on a shock. Other (cheaper) plates are available, I've only tried the M-Mar ones, so can't comment on the rest. Quote Link to comment Share on other sites More sharing options...
