ludescotty Posted May 14, 2012 Report Share Posted May 14, 2012 how do you remove the brake pedal, doesnt seem to be anywhere near enough room to pull the pedal out the way. doh Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted May 14, 2012 Report Share Posted May 14, 2012 how do you remove the brake pedal, doesnt seem to be anywhere near enough room to pull the pedal out the way. doh does it not pull forward after removing the allen bolt and maybe the rod assembly Quote Link to comment Share on other sites More sharing options...
ludescotty Posted May 15, 2012 Author Report Share Posted May 15, 2012 no, there is not much space to do anything. how should it come out? (hope nothing is bent ) Quote Link to comment Share on other sites More sharing options...
anotherfive Posted May 15, 2012 Report Share Posted May 15, 2012 Yep it does come out forward just needs a few wiggles after removing the bush/nut. and chain Quote Link to comment Share on other sites More sharing options...
ludescotty Posted May 15, 2012 Author Report Share Posted May 15, 2012 thanks for that, havent been able to get the bush/nut out as yet either, not all the way anyway. will give it another go later on, sure its just getting the angle right. Quote Link to comment Share on other sites More sharing options...
02-apr Posted May 15, 2012 Report Share Posted May 15, 2012 It's easier to just remove the swingarm - you may as well grease the bearings for all the time it takes. One of the reasons I went for a Rev3 was a dealer's advert that the rear suspension set up could be removed and refitted in fifteen minutes. Can be done in less. Quote Link to comment Share on other sites More sharing options...
ludescotty Posted May 15, 2012 Author Report Share Posted May 15, 2012 i must admit, i was thinking it would prob be easier to remove the lot lol. i remember it being a pain on the old scorpas tho so didnt bother. might have to relook at that tho cheers Quote Link to comment Share on other sites More sharing options...
