neil0965 Posted May 16, 2012 Report Share Posted May 16, 2012 Can anyone tell me what the measurements are to reposition the top shock mounts on a twinshock TY250 as per majesty? Also what should the shock length be? Many thanks in advance Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 21, 2012 Report Share Posted May 21, 2012 I can't tell you offhand what the measurement is but it is on here somewhere, I did the backend on mine a few years ago to match up with the tucked in front & ended up with the mounts being 75mm down from the originals which turned out to be very close or the same as per majesty specs Quote Link to comment Share on other sites More sharing options...
