alan bechard Posted April 26, 2005 Report Share Posted April 26, 2005 Thanks Chris, Heath, if you look at the center piece of Aluminum that is a divider you will notice that the holes do not go through, there is just a pilot there 1/8" or about 3mm and if you look at the outside cover closely you will see it has pretty big holes where the spotwelds were. Has your welding shop seen your silencer yet? If you can find a place doing that much TIG time for $16 or so, I would be all over that like white on rice. Hope you get it all back together and sorted out. Quote Link to comment Share on other sites More sharing options...
heathy Posted April 26, 2005 Author Report Share Posted April 26, 2005 I have not been to the welding shop yet, should get there at the weekend. I only explained to him over the phone what needed doing and he said around Quote Link to comment Share on other sites More sharing options...
chris Posted April 27, 2005 Report Share Posted April 27, 2005 It cost me around Quote Link to comment Share on other sites More sharing options...
john.b Posted May 4, 2005 Report Share Posted May 4, 2005 Heathy, Did you manage to get to Flavells with your welding, or is a new silencer looking more likely. Quote Link to comment Share on other sites More sharing options...
heathy Posted May 5, 2005 Author Report Share Posted May 5, 2005 I haven't been to flavels yet, still trying to split it I was thinking about getting a new one but it depends how much it is going to cost to repack this one, luckily it doesn't really matter what it looks like on a sherco because you can hardly see any of the exhaust anyway Quote Link to comment Share on other sites More sharing options...
alan bechard Posted May 5, 2005 Report Share Posted May 5, 2005 Bring it to the shop that will be doing the welding and ask them to help you get it the rest of the way apart. They will be able to do it no problem I am sure, then they can also give you a firm price to weld it back together, and you can make a sound decision from there. As someone else said here though, after they get it cracked for you, you will want to take it home and give it a thorough cleaning. When Tig welding the smallest amount of grease, oil or dirt can make things go astray. You will make the welder happy if he has spotless materials to work with when it is time to put it back together. Good luck. I just got a plasma last week, still have to put the cable on it, but I bet I can crack one FAST now! Just need to sell some Sherco brake pedals to make it worthwhile! Quote Link to comment Share on other sites More sharing options...
alan bechard Posted May 5, 2005 Report Share Posted May 5, 2005 Someone on here had a very nice picture of one that they had done. I do not think it was a Sherco, but the point would be the same either way. That could be a pretty sweet mod to do. Will have to think of that one a bit, I am about to do something with Dean's, but at the rate I am repairing things around the house, I just may slip on a new one and call it good. Quote Link to comment Share on other sites More sharing options...
heathy Posted May 7, 2005 Author Report Share Posted May 7, 2005 I am trying to decide wether of not to buy a new silencer, Does anyone know where I can get one for a good price? I have phoned malcolm rathmell and he said Quote Link to comment Share on other sites More sharing options...
heathy Posted May 7, 2005 Author Report Share Posted May 7, 2005 As I said in my op I had already cut along the original welds, it seemed like an easy job before I started. Obviousley not. I now know for next time and would advise anyone to just cut a window in the back of the exhaust! The only thing with a sherco exhaust it that there is a devider welded on the inside of the back so how would you get that out? unless you cut two windows Quote Link to comment Share on other sites More sharing options...
chris Posted May 7, 2005 Report Share Posted May 7, 2005 how long would it be before it would need repacking using a 80:1 mixture? Depends how much you use it, what oil you use, how you ride etc. I'm sure you could make it last forever if you wanted. One reason they seam to get loud is when they are used in small circiut trials (i.e. most club trials) they never get a good run to burn the excess oil/carbon off. On the other hand if you give it loads of revs for long periods of time then you risk burning the packing out, inside the exhaust. Quote Link to comment Share on other sites More sharing options...
chris Posted May 8, 2005 Report Share Posted May 8, 2005 Its impossible to make exhaust packing last forever All right then slight exaggeration there but if you only rode once or twice a year it could last over a 100 years I suppose. Quote Link to comment Share on other sites More sharing options...
heathy Posted May 10, 2005 Author Report Share Posted May 10, 2005 I've decided to order a new silencer, as the threads in the holes are also rounded off and the exhaust is a bit tatty. I found a company in TMX news (TP Off Road Sports, tel 01502 731627) who do a sherco repacking service, haven't phoned to see how much it is but I will give them a try with the new one when it needs doing. Quote Link to comment Share on other sites More sharing options...
shercomad125 Posted April 5, 2013 Report Share Posted April 5, 2013 Dose this work 100% Quote Link to comment Share on other sites More sharing options...
