keith74 Posted May 20, 2012 Report Share Posted May 20, 2012 Just bought a 250cc rev 3 and the original kill switch is still fitted to the bars but isnt wired up.Now having had a quick look at the wiring diagram and the bike it dosent really match up.There are what im guessing are plugs for the headlight(thats been removed) just behind the topyoke. Does anyone have any idea if the killswitch wires will be in this plug or if i should just run a wire from the coil to the killswitch and back?Should i fit an aftermarket killswitch as heard some bad stories of the original killswitch failing? Any help welcome.Cheers Quote Link to comment Share on other sites More sharing options...
mb4807 Posted May 21, 2012 Report Share Posted May 21, 2012 Yes. Fit an aftermarket one. Take one lead down to the coil mounting (or another reliable earth) and the other connects to a black (or might be black and white - can't remember which) wire that you should find in the area behind the headstock if you take off the right hand grill that fills in the hole in the frame. Hope that makes sense. Quote Link to comment Share on other sites More sharing options...
keith74 Posted May 23, 2012 Author Report Share Posted May 23, 2012 Thats great cheers.Just orderd up a new aftermarket switch and have found the wires i need so will wire it up as soon as i get it.Thanks for the help. Quote Link to comment Share on other sites More sharing options...
