grib Posted May 24, 2012 Report Share Posted May 24, 2012 Does anyone know how easy it would be to fit some wheels from a modern bike in to a 245? Is it just a case of making up spacers or is there problems with the disk size/offset etc? Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 25, 2012 Report Share Posted May 25, 2012 Can't you use your existing hubs with new bearings and just lace up some shiny new rims ?? Glenn Quote Link to comment Share on other sites More sharing options...
grib Posted May 25, 2012 Author Report Share Posted May 25, 2012 If I use the existing wheels then I would want to get the hubs powder coated and use a tube type front rim - I was hoping to pick up some 2nd hand wheels to make it cheaper for now. Quote Link to comment Share on other sites More sharing options...
htrdoug Posted May 25, 2012 Report Share Posted May 25, 2012 I swapped a older Beta rear wheel onto my 309,sprocket lined up but wider wheel required new spacer/disc mount. Spent a saturday or so on it and works well.best benefit was the flanged rim that requires no rim strip. (swapped because the Fantic hub had a broken sprocket mount tab) Sorry,no pics at this time. Quote Link to comment Share on other sites More sharing options...
