nakednutt Posted May 31, 2012 Author Report Share Posted May 31, 2012 when you cleaned the plates with a dremel did you take it right back to the steel? or just cleaned the groove? Quote Link to comment Share on other sites More sharing options...
nelly1 Posted June 7, 2012 Report Share Posted June 7, 2012 yes to the metal it comes off pretty easily i think there are pics and info in the beta section good luck Quote Link to comment Share on other sites More sharing options...
ham2 Posted June 7, 2012 Report Share Posted June 7, 2012 (edited) when you cleaned the plates with a dremel did you take it right back to the steel? or just cleaned the groove? Go easy with the dremel until you've taken a look at this PDF file,it's brilliant. http://www.trialscentral.com/forums/topic/28407-the-beta-clutch-fix/ Wayne Edited June 7, 2012 by HAM2 Quote Link to comment Share on other sites More sharing options...
nelly1 Posted June 8, 2012 Report Share Posted June 8, 2012 yes thats the one Quote Link to comment Share on other sites More sharing options...
nakednutt Posted June 8, 2012 Author Report Share Posted June 8, 2012 i changed the plates and took the grooves off the basket and its now spot on once warm. thanks again Quote Link to comment Share on other sites More sharing options...
