trialtrial Posted May 27, 2012 Report Share Posted May 27, 2012 I have a 2008 Beta Rev 4T. I weigh 250lbs (113kg). Obviously I need beefier front/back springs than stock. Two questions: 1. How do I determine the correct stifness of springs? 2. Where do I get them? I'll do the work in my own shop. thanks. Quote Link to comment Share on other sites More sharing options...
deminimis Posted May 29, 2012 Report Share Posted May 29, 2012 Ditto! '08 Rev3 270 and 220 pounds, but looking for the same info. Thanks. Quote Link to comment Share on other sites More sharing options...
deminimis Posted May 30, 2012 Report Share Posted May 30, 2012 TT, I just ordered the only fork spring in stock from The Splat Shop. Dims are: 365mm long by 32mm outer diameter. Spring rate 0.9kg/mm (8.8N/mm). Cannonracecraft can build you one, but it will cost more than the approx $80 shipped (to the US) Splat Shop price (Cannonracecraft quoted me $175 for two (didn't understand I only needed one)). I am working on dims for the shock and will likely have Cannon build that. If anyone has the factory dims on the shock spring (2008), please chime in. I assume it's a progressive spring as the shock valving is progressive. I'm guessing the rear shock needs to be in the 80N/mm range, but any info would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted June 5, 2012 Author Report Share Posted June 5, 2012 Thanks for the info. My local distributor has fork springs, but nothing for the shock. I am having a hard time finding out even why type of shock it is?!? Quote Link to comment Share on other sites More sharing options...
pindie Posted June 5, 2012 Report Share Posted June 5, 2012 Paioli if its on a rev 3? Back spring, grey shock body. One small allen adjuster at the top and rear of the shock. Quote Link to comment Share on other sites More sharing options...
