trialswarrior Posted May 28, 2012 Report Share Posted May 28, 2012 One of the fork seals is stuck real bad. It took an usual amount of slide hammer motions to separate the stanchion from the slider. However, once I got the two separated I noticed that part of the seal was still in there. The slider and bushing just ripped through the seal leaving the outer seal race in the stanchion. I'm thinking to use a dremel tool and carefully cut the seal race. Has anyone run into the same problem and what worked best to solve it ? Quote Link to comment Share on other sites More sharing options...
billyt Posted May 28, 2012 Report Share Posted May 28, 2012 Did you remove the wavey retaining clip first before trying to pull out the old seal? Quote Link to comment Share on other sites More sharing options...
copemech Posted May 28, 2012 Report Share Posted May 28, 2012 Did you remove the wavey retaining clip first before trying to pull out the old seal? Jeez Billy, ya thin hes thick, hees sen the restofit! Quote Link to comment Share on other sites More sharing options...
billyt Posted May 28, 2012 Report Share Posted May 28, 2012 "ya thin hes thick, hees sen the restofit!" Cope, you are starting to write like you speak, you must be from Texas with penmanship like that ! LOL Was that your attempt at an Austrian accent? Maybe you where asking me if I thought he was dumb? No I was not, many smart people have forgot about the wavy retaining clip and just start banging away. Quote Link to comment Share on other sites More sharing options...
trialswarrior Posted May 28, 2012 Author Report Share Posted May 28, 2012 "ya thin hes thick, hees sen the restofit!" Cope, you are starting to write like you speak, you must be from Texas with penmanship like that ! LOL Was that your attempt at an Austrian accent? Maybe you where asking me if I thought he was dumb? No I was not, many smart people have forgot about the wavy retaining clip and just start banging away. Yes, I had removed the clip. First time I've ever seen this happen. Some how the bushin at the bottom of the slider and the one just below the seal got through the seal without pulling it out. I guess the outer seal race is too thin and didn't catch the bushins. So now how do I get what's left of the seal out ? Quote Link to comment Share on other sites More sharing options...
ducati996 Posted May 28, 2012 Report Share Posted May 28, 2012 i had same problem last wk with gas gas 125 where slider came out & left seal behind i gently tapped screwdriver between seal & fork leg because seal was plastic i managed to bend seal & lever out Quote Link to comment Share on other sites More sharing options...
billyt Posted May 28, 2012 Report Share Posted May 28, 2012 I guess this means your bushings are wore out? Quote Link to comment Share on other sites More sharing options...
pandelboy Posted May 28, 2012 Report Share Posted May 28, 2012 i had same problem last wk with gas gas 125 where slider came out & left seal behind i gently tapped screwdriver between seal & fork leg because seal was plastic i managed to bend seal & lever out if this was the marzzochi forks then the bushings do not bring out the seal, it will slide right past it only the older forks pre 2005 pulled out the seal with the stanchion. on the gassers im talking about. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 28, 2012 Report Share Posted May 28, 2012 (edited) many smart people have forgot about the wavy retaining clip and just start banging away. Reminds me of the old joke "If I knew you were a virgin I'd have taken more time" - girlfriend reples "If I knew we had more time I'd have taken my tights off" The morale of this story is - don't spoil things by rushing. If the outer part of your seal is metal go very gently with the dremmel - don't want to spoil the housing. A way I have used is to MIG weld an old bolt onto the band. This works well with needle roller races in swing arms as well but you have to shield carefully against MIG spatter damage. If the outer part is just "rubber" a paint stripping hot air gun will soften it. Cheers Edited May 28, 2012 by Dadof2 Quote Link to comment Share on other sites More sharing options...
ducati996 Posted May 28, 2012 Report Share Posted May 28, 2012 if this was the marzzochi forks then the bushings do not bring out the seal, it will slide right past it only the older forks pre 2005 pulled out the seal with the stanchion. on the gassers im talking about. yes it did have marzzochi forks 2010 Gas Gas Quote Link to comment Share on other sites More sharing options...
trialswarrior Posted May 29, 2012 Author Report Share Posted May 29, 2012 I was able to remove the leftover seal race. I used a dremel tool to cut through it at an angle, just enought to pry a screwdriver in and lift a piece of it enough for the nose pliers to have something to grab. It came right out. Quote Link to comment Share on other sites More sharing options...
