sherpat Posted May 28, 2012 Report Share Posted May 28, 2012 Hi All, I just bought a 1982 TL320, and would like to change the fluids. I searched the web, but wasn't able to find the info. So the question is, how much oil for the gearbox; and how much oil for the Betor forks? Thanks. Quote Link to comment Share on other sites More sharing options...
sherpat Posted May 28, 2012 Author Report Share Posted May 28, 2012 Forgot to post a pic. 1 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted May 28, 2012 Report Share Posted May 28, 2012 (edited) Just replaced the oil in the gear box, 1.2l is noted in the handbook, very much indeed, there is a small screw on the clutch side which I believe is the level controll screw, I had to use a litle bit more then 1.2l around 1.3 to fill up to this point, used Elf HTX 740. To the fork as it is a 35mm Betor 180 cc is standard for Bultaco up to 220 cc which is stated by SWM, but I have some doubts if 220 cc isn't too much? Edited May 28, 2012 by PSchrauber 1 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted May 28, 2012 Report Share Posted May 28, 2012 Forgot to post a pic. Very nice bike indeed! Quote Link to comment Share on other sites More sharing options...
sherpat Posted May 28, 2012 Author Report Share Posted May 28, 2012 Thanks PSchrauber, I appreciate the info! You're right 1.2L does sound like a lot, I was expecting about half that. Great tip with the oil level screw, I hadn't noticed that. I think I'll split the difference with the forks, and start at 200cc. I'll see how that works, and go from there. Thanks again! Quote Link to comment Share on other sites More sharing options...
martinm Posted June 3, 2012 Report Share Posted June 3, 2012 Thanks PSchrauber, I appreciate the info! You're right 1.2L does sound like a lot, I was expecting about half that. Great tip with the oil level screw, I hadn't noticed that. I think I'll split the difference with the forks, and start at 200cc. I'll see how that works, and go from there. Thanks again! Its 220cc of 10W oil in each leg for SWM Betors......just like it says in the book. 1 Quote Link to comment Share on other sites More sharing options...
