Techno Coolant Level
rallymadsam
I've just done a bit of work to my Techno, and now just giving it a few short test rides etc. to make sure all is OK.
I replaced the coolant up to 'min' level on the resevoir, tried to pump as much through as possible by pumping the bottom hose by hand and bleeding some out at the pump, then ran it up to temperature, waited for fan to kick in and topped it back up, all seems OK, then next time I went to the bike when cold there's nothing showing on the tank, so did same again, all seemed OK, stopped bike. Then 1/2 hour later looked and nothing showing in tank again.
So, 2 questions:
1: How much coolant should it take?
2: Why does it keep disappearing from the tank?
I've just done water pump seal, and changed g/box oil since, so it's not going in there.
Any ideas?
