Gas Gas Pro Clutch
bobbylovely
I have just changed the clutch plates on my 06 Raga 300. I replaced the 2 o rings and bleed out the system. It all runs and gears engage fine but when its i pull the clutch in, and stand stationary the bike still seems to want to drive forward. Any suggestions. Could it need adjustment if so how do I go about it. Or could it still be air in the system.
Mine creeps slightly after changing to atf. I prefer a really aggressive bite and I did't like the feel when running on Putoline but it did not drag.
I got used to the slight drag and find it easy to compensate with brakes.
If you have just replaced the clutch it could be down to measurements see the videos on gg usa.
