neilh Posted June 2, 2012 Report Share Posted June 2, 2012 apart from the stuff on the shelves that is specific "air filter oil" what else can you use to oil air filters? Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted June 2, 2012 Report Share Posted June 2, 2012 Filter oil is "Special" because it has a "Tackifier" which stops the oil draining to the bottom of the filter leaving the top portion dry - trick is to leave the filter out of the bike overnight before fitting, to ensure the best result - do not over-oil. Quote Link to comment Share on other sites More sharing options...
neilh Posted June 2, 2012 Author Report Share Posted June 2, 2012 so are you saying there are NO alternatives other than to use shop bought air filter oil? Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted June 2, 2012 Report Share Posted June 2, 2012 Whats wrong with using the correct oil for the job? Its not like its expensive to stop dirt entering your engine. Quote Link to comment Share on other sites More sharing options...
0007 Posted June 2, 2012 Report Share Posted June 2, 2012 Just curious but why would you want to use something else?, it's not exactly overpriced and a bottle lasts a long time Air filter oil is tacky like Dave mentioned and wont settle to the bottom of the filter It wont gel if water gets in it, it won't catch fire I don't think there is a suitable alternative Quote Link to comment Share on other sites More sharing options...
neilh Posted June 2, 2012 Author Report Share Posted June 2, 2012 im asking because im a mechanic, and i work in a garage. i have access to all different types of oils in abundance, which i can have for free. this in turn will reduce any expense and out goings i have on bike maintainance. to put it quite simply, i think this "special" oil is a gimmick. if i have to purchase it i will, but i wont if i already have 45 gallons of a particular oil that will do the job nicely. Quote Link to comment Share on other sites More sharing options...
manofsteele Posted June 2, 2012 Report Share Posted June 2, 2012 I'm a mechanic too and I can say air filter oil is special stuff, not like anything else in our trade. A bottle of it will last you for ages too, so expense-wise it won't be high up your list. I use the aerosol stylee myself; clean & dry your filter, a light spraying with yer posh air filter oil, massage in and leave overnight to dry. I have a couple of filters on rotation to take the hassle out of it. Robert's your mothers brother. I did try the non aerosol style but found I kept over oiling the filters, never could get it quite right. I have heard of people simply washing their filters in premix and leaving them overnight then banging them straight back in the bike. Not sure I fancy that myself, but each to his own. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 2, 2012 Report Share Posted June 2, 2012 Before there was "air filter" oil people used car engine oil or two stroke premix oil on foam air filters. It will work fine if you oil the filter the night before, or on the day of the ride. Not long after that though it migrates downwards, making a bit of a mess in the filter casing, and leaving the top section dry. I use a proper air filter oil mainly so I can service the air filter well in advance of the ride when I have the time available. Quote Link to comment Share on other sites More sharing options...
copemech Posted June 3, 2012 Report Share Posted June 3, 2012 One should sort of relate the "tacky" air filter oils to one them sticky bug traps! You want to catch all you can and hold it! Quote Link to comment Share on other sites More sharing options...
0007 Posted June 3, 2012 Report Share Posted June 3, 2012 Maybe you don't quite get how a filter works, the oil IS the filter, the foam just suspends the oil It it's very thick but has a carrier that evaporates so it goes on thin and afterwards it gets gooey There's no engine or gear oil like it Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 3, 2012 Report Share Posted June 3, 2012 (edited) Both me and my son have trials bikes. Both bikes get the filters cleaned and filter oiled EVERY weekend. I have just bought a new aerosol of filter oil , it cost about a tenner !! This is the first one I've bought in over 12 months !! I don't think cost is an issue for the correct stuff. Phil Edited June 3, 2012 by Pistonbroke Quote Link to comment Share on other sites More sharing options...
neilh Posted June 3, 2012 Author Report Share Posted June 3, 2012 ok i tihnk you're all completely missing my point. ive got no problem buying the air filter oil if thats all that will do the job correctly. regardless of whether it costs a tenner for a year or not. im simply saying that if there is some other, more generic oil out there that will do the job then i may already have some as we buy oils in bulk. Quote Link to comment Share on other sites More sharing options...
jse Posted June 3, 2012 Report Share Posted June 3, 2012 ok i tihnk you're all completely missing my point. ive got no problem buying the air filter oil if thats all that will do the job correctly. regardless of whether it costs a tenner for a year or not. im simply saying that if there is some other, more generic oil out there that will do the job then i may already have some as we buy oils in bulk. I doubt you will find a good, safe generic replacement. The qualities of motorcycle foam filter oil are quite specific, for one, the dispersing solvent is designed not to deteriorate the open cell foam material or the special cement used to hold the filter together. Get the wrong oil and you've just ruined a lot of customer's engines. Jon Quote Link to comment Share on other sites More sharing options...
neilh Posted June 3, 2012 Author Report Share Posted June 3, 2012 which is why i asked the question initially. Quote Link to comment Share on other sites More sharing options...
monty_jon Posted June 3, 2012 Report Share Posted June 3, 2012 (edited) ok i tihnk you're all completely missing my point. Can’t see your point, why would you want to use anything other than the correct oil? If you had loads of filter oil would you use that for a car oil changes,, or do you use any old oil… As your a mechanic I would think the answer is quite obvious Edited June 3, 2012 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
