7 Posted June 3, 2012 Report Share Posted June 3, 2012 hi all,having trouble with 2010 gas gas 250cc clutch,put new dp clutch in it everything working spot on rode it for half hour all ok then the clutch leaver has got very stiff any ideas Quote Link to comment Share on other sites More sharing options...
bmseven Posted June 3, 2012 Report Share Posted June 3, 2012 what oil did you put in? Quote Link to comment Share on other sites More sharing options...
7 Posted June 3, 2012 Author Report Share Posted June 3, 2012 hi,putoline gp10 400ml Quote Link to comment Share on other sites More sharing options...
chris91 Posted June 3, 2012 Report Share Posted June 3, 2012 did you set the clutch up i.e measure the pack width, and the distance between the clutch spring and plate (how hight the springs sit) Quote Link to comment Share on other sites More sharing options...
7 Posted June 3, 2012 Author Report Share Posted June 3, 2012 hi no did not measure clutch pack because when you buy a dp clutch its measured to go stright in from the packet,fitted loads of these clutch packs stright from the box not had any probs ??? Quote Link to comment Share on other sites More sharing options...
chris91 Posted June 3, 2012 Report Share Posted June 3, 2012 I would be inclind to remove clutch and check if it was me. I would not expect oil to make clutch leaver go hard, would expect it to course drag or slip. If all was fine before that clutch was fitted i would remove measure pack width with should be between 9.75-9.85mm and the clutch fingers need to between 16-19mm check out this video = http://youtu.be/336BDbcZEMM Quote Link to comment Share on other sites More sharing options...
bmseven Posted June 3, 2012 Report Share Posted June 3, 2012 Have a read of this one http://www.trialscentral.com/forums/topic/41758-gas-gas-clutch-work/ Quote Link to comment Share on other sites More sharing options...
coxy Posted June 3, 2012 Report Share Posted June 3, 2012 Definitely take the clutch out and check the pack height, the clutch pack is suppose to be measured to size but when i bought one for my last bike when i measured it as soon i received it the pack height was exactly 10mm so had to jiggle it about abit with plates i had etc to get it to te correct size. The fact that your lever has become harder to pull will be because the clutch pack is too big and the small levers will not have as much mechanical advantage Quote Link to comment Share on other sites More sharing options...
fastbelly Posted April 14, 2016 Report Share Posted April 14, 2016 Hi, old thread I know. My 2013 clutch has gone stiff to use. I just pulled it apart and the stack measures 10mm exactly according to my vernier. Sounds like that is too big? How can a clutch grow? You would assume it would get smaller with wear? Incorrect oil? Latest I used was ATF. Its a standard clutch set. A youTube video shows a guy lapping his friction plates to bring the stack to within tollerance. Good idea? I have acces to a surface table. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted April 14, 2016 Report Share Posted April 14, 2016 Yes certain oils react with the clutch fibres. I used to always use atf without any problems. My current bike has been used to a diet of putoline light gear oil and recently I had to swap some plates round as the pack had expanded. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 14, 2016 Report Share Posted April 14, 2016 Its ''easily'' fixable. You need to set the pack thickness and the fingerheight spot on and it will work just fine. Packt hickness +- 9.75 to 9.85mm Finger height aim at 17,5mm Also check play on the lever should have arround 3mm of free play. Quote Link to comment Share on other sites More sharing options...
fastbelly Posted April 14, 2016 Report Share Posted April 14, 2016 So, to set the pack thickness I can lap the friction plates? I also seem to have wear on the fingers, looking at them I can install em the otherway up and they will work as new. Correct? Loving the advice chaps. Quote Link to comment Share on other sites More sharing options...
heffergm Posted April 14, 2016 Report Share Posted April 14, 2016 I'm still confused as to why people with modern GG's use ATF? The manual pretty clearly says 75W gear oil... Quote Link to comment Share on other sites More sharing options...
cbutler Posted April 14, 2016 Report Share Posted April 14, 2016 Probably because Jim Snell did extensive testing and determined ATF to work better in the PRO motor. I have never seen a trials service Manuel but if it is ANYTHING like the Enduro Manuel Id throw it in the trash. 1 Quote Link to comment Share on other sites More sharing options...
heffergm Posted April 14, 2016 Report Share Posted April 14, 2016 (edited) I know Jim is well respected and whatnot, but I'd still never put ATF in a gearbox, especially one that also lubricates the bottom end. But what do I know... Edited April 14, 2016 by heffergm Quote Link to comment Share on other sites More sharing options...
