fastbelly Posted April 18, 2016 Report Share Posted April 18, 2016 Doh. Didnt think of that. Thanks. Glenn Quote Link to comment Share on other sites More sharing options...
fastbelly Posted April 18, 2016 Report Share Posted April 18, 2016 Right, I am glad to report that my clutch is absolutely perfect! Glenn. 2 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 18, 2016 Report Share Posted April 18, 2016 And you wont believe it, but if you know how to set it absolutely right, its can be even better! You need measuring clocks and some nice tools (and time). https://www.facebook.com/takanori.kitamura He is a pro in making cluthes spot on. https://www.facebook.com/2011trproduct/?fref=ts Quote Link to comment Share on other sites More sharing options...
lian Posted April 19, 2016 Report Share Posted April 19, 2016 Quote You could of saved all that sanding just by burning that clutch in. Fourth gear against a tree and give her hell. Test, and give it another good burn. 5 minute job. Do you mean slipping the clutch while reving or just only keep throttle? Because i've wasted much time with sand paper too.. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 21, 2016 Report Share Posted April 21, 2016 Rev it and slip the clutch against a whall or something with all the brakes on. 1 Quote Link to comment Share on other sites More sharing options...
sting32 Posted April 21, 2016 Report Share Posted April 21, 2016 On 4/16/2016 at 11:31 AM, zippy said: I RESIST, I WILL USE AUTOTRAK II (2 reasons, it is what the bike came with when I bought it and don't want issues with changing fluid. and it's blue just like the plastics on my bike ) Autotrak2 oils have pretty much been stated cause swelling of clutch materials. this was back in 08 or sometime in history, just sayin, everyone else has moved away from it. Quote Link to comment Share on other sites More sharing options...
smarty156 Posted May 8, 2016 Report Share Posted May 8, 2016 I've just replaced the clutch pack on my 2014 Racing as the lever was very stiff. Got a Surflex clutch pack with 5 steel plates and picked 2 that got the pack to 9.8mm. Put it all back together with new Putoline Light Gear Oil (as recommended by Factory Kev at GasGasUK) and now its lovely and light. However, it was slipping in 5th and 6th gear when I tried it today. What could cause that? There was possibly slightly too much oil in as it was about 2/3rds of the way up the sight glass rather than midway. Could that do it? I've made sure there's lots of slack at the lever. Any ideas before I pull it all apart again ? Quote Link to comment Share on other sites More sharing options...
heffergm Posted May 8, 2016 Report Share Posted May 8, 2016 2/3rds vs half way up the glass is probably about 20ml of oil. It would make zero difference. Not sure about the slipping on a new clutch. I'd have to guess something went together incorrectly. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 9, 2016 Report Share Posted May 9, 2016 I always put in 380mm when its totally empty. Little below the glass. Too much is not good imo. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 9, 2016 Report Share Posted May 9, 2016 The plates are under more pressure when fitted than when measured with a vernier or other gauge. Brand new plates will also bed in a little, just taking high points of the fibres could easily make 0.1mm difference.Just been through this process myself and I measured the pack at 9.75mm. However although it didn't slip the clutch wasn't fast enough when trying to jump across stuff. When I took it back out its now less than 9.7mm after one trial. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 9, 2016 Report Share Posted May 9, 2016 They can even become more thick! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 9, 2016 Report Share Posted May 9, 2016 Yes they can depending what oil is used Quote Link to comment Share on other sites More sharing options...
smarty156 Posted May 9, 2016 Report Share Posted May 9, 2016 (edited) Well I remeasured the finger height and it's spot on. Normally I can be a little bit heavy handed when doing nuts and bolts up. I'm thinking I may have been a little too cautious when I replaced the plates and not tightened the retaining bolts up quite enough. Have re-tightened them all. Also checked the bearing, washer, replaced the clutch cover gasket and put it all back together. I'm hoping its now sorted but I don't have a trial until 22nd so I won't know until then. Edited May 9, 2016 by smarty156 Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 10, 2016 Report Share Posted May 10, 2016 The newer pro`s required the thickest friction plate to be installed first. At the same time the newer bikes have the light spring. Quote Link to comment Share on other sites More sharing options...
smarty156 Posted May 10, 2016 Report Share Posted May 10, 2016 All the Surflex friction plates are the same thickness. It's the metal plates that they give you different thicknesses of (1.3mm, 1.4mm, 1.5mm and 2 x 1.6mm). Quote Link to comment Share on other sites More sharing options...
