jreilly Posted June 7, 2012 Report Share Posted June 7, 2012 Wondering if anyone has installed the Boyesen carbon tech reeds in a Gas Gas Pro 300?Just put a set in sons bike. Thanks JR Quote Link to comment Share on other sites More sharing options...
copemech Posted June 7, 2012 Report Share Posted June 7, 2012 Soo what are your findings? Quote Link to comment Share on other sites More sharing options...
jreilly Posted June 7, 2012 Author Report Share Posted June 7, 2012 Have not had a chance to try yet . Was looking for any in put on carb mods that might need to be done.We have a ride this weekend to sort it out.He rides expert line so does no good for me to evaluate .Will post results.JR Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 7, 2012 Report Share Posted June 7, 2012 mine just needed air screw adjustment. Quote Link to comment Share on other sites More sharing options...
steve fracy Posted June 7, 2012 Report Share Posted June 7, 2012 MY son has them in his 2012 Beta Evo 3002t and they work very well!!! ( Thanks to support from Mike Komer and Boyesen) Quite different than the V-Force we had before! Just a slight air screw adjustment for us too! Well worth it! Steve Quote Link to comment Share on other sites More sharing options...
jse Posted June 7, 2012 Report Share Posted June 7, 2012 On 6/7/2012 at 1:11 PM, Steve Fracy said: MY son has them in his 2012 Beta Evo 3002t and they work very well!!! ( Thanks to support from Mike Komer and Boyesen) Quite different than the V-Force we had before! Just a slight air screw adjustment for us too! Well worth it! Steve I've used the dual-stage reeds in all my off-road race engines and my personal bikes since Boyesen came out with them. I swear by them as my experience has been they are a very good product and give good value for the expense. I did some dyno testing years ago and they gave boost all throughout the rev range. I have not used the single stage carbon reeds but I would bet they do the job. Jon Quote Link to comment Share on other sites More sharing options...
copemech Posted June 8, 2012 Report Share Posted June 8, 2012 On 6/7/2012 at 10:56 AM, Nigel Dabster said: mine just needed air screw adjustment. And how do they compare to the dual stage? Quote Link to comment Share on other sites More sharing options...
jreilly Posted June 8, 2012 Author Report Share Posted June 8, 2012 Thanks for the imfo guys.Was hoping that it would just be some slight adjustments.JR Quote Link to comment Share on other sites More sharing options...
steve_earle Posted June 10, 2012 Report Share Posted June 10, 2012 been looking at theese too, I can't find much info on the dual stage vs carbon. Would be good to know the actual difference between how they deliver power at what revs etc. I would guess that the carbon ones are better at high revs but the others better at bottom & mid response. Quote Link to comment Share on other sites More sharing options...
jreilly Posted June 12, 2012 Author Report Share Posted June 12, 2012 My son had a good day of riding the gasser with the new carbon tech reeds installed.But it was a muddy day so not the best conditions to evaluate the reeds,not much high rpms going on.Just a miner carb adjustment needed. Now for another ? thing when bike is warm and shut down it starts very hard seems to not be getting fuel.It was doing this before the new reeds where installed.Is this because it does not have the keihin carb or what. Thabks Jim Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 12, 2012 Report Share Posted June 12, 2012 dellorto? Checked banjo filter, and float level? you could get a bigger needle valve if ness after the above. Quote Link to comment Share on other sites More sharing options...
jreilly Posted June 12, 2012 Author Report Share Posted June 12, 2012 Yes Nigel it is the dellorto carb.Did not see anything in the banjo filter.Do you know what height the float is supposed to be at? Thanks JR Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 12, 2012 Report Share Posted June 12, 2012 18.5 was sherco height if i remember right, you can get a bigger needle valve if everything else is spot on Quote Link to comment Share on other sites More sharing options...
copemech Posted June 23, 2012 Report Share Posted June 23, 2012 Reeds Dabster Reedds! Did you compare the dual stage to the carbon? Quote Link to comment Share on other sites More sharing options...
steve_earle Posted June 26, 2012 Report Share Posted June 26, 2012 I have bit the bullet and ordered some carbon reeds today, My therory being that they will give me a sharper power delivery than the dual stage reeds that will suit my riding style as i use 2nd or 3rd most of the time and crack it hard off the bottom. I have also ordered a Thor titanium front pipe. I have a 09 300 with a high compression head, Still using the delorto but keep looking at a kehin the only thing holding me back is reports that they smooth out the bottom end and i like the instant snap. Im not a rev to the moon and dump the clutch rider as I dont want to wreck my bike so I need bottom end for instant blast!! I have a 2 day trial at the week end so will report back on my findings. Quote Link to comment Share on other sites More sharing options...
