cwill83247 Posted June 10, 2012 Report Share Posted June 10, 2012 Just popped out on the bike for an hour and noticed I have a crack on the casing very close to the kickstart shaft.. Does anyone know what would case this ? dont want to buy a new case and then crack another case...as they are 90 quid a time.. any advice help would be appreciated Thanks Chris Quote Link to comment Share on other sites More sharing options...
ducati996 Posted June 10, 2012 Report Share Posted June 10, 2012 Had same problem on gas gas 280 cracked from shaft to clutch cover bolt,hell of a job to weld as they r alloy/magnesium,think its down to wear on quadrant/pinion give Trials UK a ring they will advise you. Quote Link to comment Share on other sites More sharing options...
