razorback Posted June 11, 2012 Report Share Posted June 11, 2012 I recently picked up a used 2011 Raga 300 and am using it to build/clear mountain bike trails and I need to slow it down and smooth it out as much as I can. I've dropped the front tooth to a 10 and installed a slow throttle tube which helps but now I want to smooth it out and make it more "chugable" if that's a word. I'm thinking of adding a S3 flywheel weight as that is easy to get in the states. Is the S3 brand a good one or is there a better one? Also, I'm considering lowering the compression with a new insert. The current insert has a "30T" stamped by the spark plug. Does anyone know which head insert it has in it? If I do the new insert, what carb changes will be required? I'm an senior newbie and don't really want to compete but instead just have fun with it. I appreciate any advice. Here she is when I got her: Quote Link to comment Share on other sites More sharing options...
godzilla Posted June 11, 2012 Report Share Posted June 11, 2012 I like your bike rack, do they have a web site? Sorry to go off topic. Quote Link to comment Share on other sites More sharing options...
neale Posted June 11, 2012 Report Share Posted June 11, 2012 I like your bike rack, do they have a web site? Sorry to go off topic. I very much doubt you would find that rack to be legal in the UK. Quote Link to comment Share on other sites More sharing options...
godzilla Posted June 11, 2012 Report Share Posted June 11, 2012 I very much doubt you would find that rack to be legal in the UK. Might look a bit mental on the front of my hatchback no doudt, i was thinkin more of fabricating a rear bike rack not using the Scorpa as a bull bar. Quote Link to comment Share on other sites More sharing options...
razorback Posted June 11, 2012 Author Report Share Posted June 11, 2012 The carrier is more than 20 years old and the company that made it is long gone unfortunately. It's a nice rack though and it tilts as well. Quote Link to comment Share on other sites More sharing options...
sting32 Posted June 11, 2012 Report Share Posted June 11, 2012 (edited) I would ask a previous owner? or who you bought it from... Now please note, I dont "know for sure" but would bet, that most even Raga's shipped with standard compression insert, I know my buddy had to purchase higher compression for his, when he went to Co Nationals, but his is the previous year raga, so I think a call to Lewissport or rising son or importer, might be in order, that is to verify against my assumptions, if it is Critical knowledge you seek. My bet is it shipped with a std compression insert, with lower and higher you can buy from suppliers/local dealers. My dad has this same bike, Ill try to remember to look at his tonight, post later or tomorrow if I remember. Edited June 11, 2012 by sting32 Quote Link to comment Share on other sites More sharing options...
razorback Posted June 11, 2012 Author Report Share Posted June 11, 2012 The previous owner says it's stock but really I'm just curious which it is. If you think about it, please check your dads bike if you don't mind. The real question is if I have to make any carb changes, like jetting, when switching inserts. I would think not but just thought I'd ask the collective knowledge here. Appreciate the response. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted June 11, 2012 Report Share Posted June 11, 2012 The S3 flywheel is good (and for some of us, essential to tame the abrupt power delivery of the Raga. But you do need to drill some holes in the original flywheel to get the S3 to fit. Quote Link to comment Share on other sites More sharing options...
razorback Posted June 11, 2012 Author Report Share Posted June 11, 2012 Thanks for that bit of info. I have looked for the installation instructions on line but I have found nothing yet. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 12, 2012 Report Share Posted June 12, 2012 When installed there were no externally visible identifying marks on the S3 low compression head insert I had in my 2010 Raga, however it was marked '300B'. Quote Link to comment Share on other sites More sharing options...
aussiechris Posted June 12, 2012 Report Share Posted June 12, 2012 I have the same bike (since new) and I love it. But the power is wicked. Your bike will have a black outer head. The insert you can see with 30T on it should be silver. That is standard compression. A high compression insert is red and the low compression one is black. S3 is fine - I understand the original head is an S3 Stars item anyway A low compression head and flywheel weight should make it into a smooth running torque monster. Be sure to let us know how you go. Chris Brisbane Australia. Quote Link to comment Share on other sites More sharing options...
razorback Posted June 12, 2012 Author Report Share Posted June 12, 2012 Lowbrow, I don't mind drilling or tapping the original flywheel so the S3 should be OK and I can get the S3 stuff in the states pretty easy. Thanks for the info. Chris, you are spot on. It does have the black outer head and the insert under it is silver with the 30T on it so it must be a standard compression insert like you say. I agree, it is one sweet bike. I marvel at how simple it is when I work on it compared to my big bore dirt bikes and I LOVE it's light weight. I appreciate the information guys, I'll order the flywheel weight and insert later today and will report back when I get them installed. Quote Link to comment Share on other sites More sharing options...
michael martin Posted June 14, 2012 Report Share Posted June 14, 2012 Put a slow turn throttle tube on it and ride it. Then ride it some more......... Quote Link to comment Share on other sites More sharing options...
razorback Posted June 15, 2012 Author Report Share Posted June 15, 2012 The first thing I did... Put a slow turn throttle tube on it Quote Link to comment Share on other sites More sharing options...
arnoux Posted June 15, 2012 Report Share Posted June 15, 2012 (edited) "The S3 flywheel is good (and for some of us, essential to tame the abrupt power delivery of the Raga. But you do need to drill some holes in the original flywheel to get the S3 to fit." by TooFastTim As a long time S3 importer and dealer I can assure you that you do NOT have to drill any holes to fit the S3 Flywheel weight kit. I think TooFastTim is confusing it with the HEBO weight. The S3 kit is literally a 5 minute job to fit to the Gas Gas Pro flywheel . The flywheel must be removed the first time the S3 kit is fitted, This is so the supplied two threaded inserts can be fitted into two existing holes in the flywheel from the back/stator side. A round or "rat tail" file is needed to file a small portion of thin sheet steel that partially blocks these two holes. Then the flywheel weight can be bolted on from the outside. If you need to remove the weight in future the flywheel can stay on the bike. It is the HEBO kit that needs the flywheel to be drilled (but it is also a good kit - just different initial fitment). A spacer and gaskets are supplied to space out the side cover, allowing for the extra room the weight takes up, but the standard gear lever can still be used. Head insert on RAGA is standard comp S3. You can fit a Low-Comp insert to"soften" the bike. Or change the standard 0.5mm base gasket for a 0.8 or 1mm base gasket. regards Edited June 16, 2012 by arnoux Quote Link to comment Share on other sites More sharing options...
