andy m Posted June 11, 2012 Report Share Posted June 11, 2012 is anyone here using a Delorto carb phb 25 or 26 on a Bantam ?? Just wondering what jet sizes you are using. I have had it bored to 186cc with a Suzuki piston. Have tried a 25 which was off a Fantic 200 , it may be past its best, started okay but didn't run too well when warm, also a 26 which I believe was off a Gasser, the jets are the same ?? again starts okay, may run a bit better. Not able to take the bike out yet just getting sorted. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted June 11, 2012 Report Share Posted June 11, 2012 I run an Amal on mine (old british carb). 1" bore, runs good... Quote Link to comment Share on other sites More sharing options...
goudrons Posted June 11, 2012 Report Share Posted June 11, 2012 You can get Mikuni to work well on the Bantam. VM26-8074 Main 130, Pilot 35, Slide 2.0, float valve 2.5, needle jet 182-P0, Needle 5DP39, Air jet 0.5 Eurocarbs may have some idea for a Dellorto http://www.dellorto.co.uk/ Quote Link to comment Share on other sites More sharing options...
