cdubb Posted June 11, 2012 Report Share Posted June 11, 2012 I am having difficulties getting the cluch to properly respond to the clutch lever. Long Winded explination, please bear with me: Clutch lever will not disengage cluch plates. If I pull on the lever, the bike stays in gear, cannot push bike. I tried to adjust the adjustment screw and nut. What I was able to get was enough preload on the clutch diaphram to be able to pull the lever to disengage the cluch plates (only slightly) but when I went to install the adjustment screw nut, there was no thread left on adjustment screw to allow the nut to be fitted on the screw. I'm thinking this would not be acceptable as this would indicate that there is too much pre-load on clutch diaphram. Another indication of overload on diaphram, is when adjusting the screw to the preferrable setting mentioned above, I was less that 1/4 turn to having the clutch plates disengaged even when in gear. (i.e. I was able to push the bike as if it was in neutral, with minor additional friction, when the bike was in gear). What is going on!? Is my cable the incorrect one? Is it too long? Or is my clutch stack height too thin? What is the stock length of a clutch cable on a '75 Alpina 350? What is the proper stack height? Quote Link to comment Share on other sites More sharing options...
woody Posted June 11, 2012 Report Share Posted June 11, 2012 If you do a search on clutch adjustment there are two or three seperate articles on how to set up the clutch from a while back. Shouldn't be too hard to find Quote Link to comment Share on other sites More sharing options...
woody Posted June 11, 2012 Report Share Posted June 11, 2012 There should be a ball bearing between the pushrod and the 'mushroom' that acts upon the pressure plate. The fact that you have no thread left indicates the ball bearing may be missing. 1 Quote Link to comment Share on other sites More sharing options...
cdubb Posted May 2, 2013 Author Report Share Posted May 2, 2013 Woody you were right on.. the ball was missing! Quote Link to comment Share on other sites More sharing options...
