Bantam / Cub Swing-Arm Length
suzuki250
Progress of swing-arm One side finished, other sidw still needs filing down
I think I’ll have a go at making some alloy Cub Hubs next
(Can’t make up my mind if I’m going to turn them from billets or cast them, If I cast I will make a few sets :thumbup:)
Edited by suzuki250
  • 7 months later...
I’m now in the process of making my hubs and yokes, yokes are nearly finished just need to make the spindle and bar risers
It’s taking a little longer than planed as don’t seem to have a lot of time at the moment (wifes just had a baby!)
I will post some pics of the hubs soon
Edited by suzuki250
Hi Guys.
Hi Suzuki.
Bad Engineering practice extending the arm like that, now you have two welds to break?
Do your homework on the hubs , it is far cheaper to buy some than to make your own. And you know the ones that are already tested work, been there as they say, Give Alan a ring.
Regards Charlie.
Hi Guys.
Hi Suzuki.
Regards Charlie.
I would disagree on the welding, I have inserted a bush into the swing-arm (see pic) even if they were butt welded I would be surprised if it did fail as most of the stress is transmitted though the shocks the swing arm acts more like a control arm than on a modern mono-shock bike (but I’m not the best welder!)
I have worked many years as an Automotive prototype engineer / quality engineer, after serving a technical engineering apprenticeship so I would hope my work would be satisfactory :thumbup:
But I would agree its not worth the time making parts, if you don’t have a CNC machine. But I’m in the process of buying one :D
I’m sure you would agree most of the fun is making your own parts, I find it very satisfying
Edited by suzuki250
the reply regarding bad enginnering practice is outrageous you trained in prototype enginnering the same as myself and with 40 years in the game i see nothing wrong with that work at all.my bantam swinging arm has been extended by one inch by cutting the 5/16 flat plate where the spindle sits and welding one inch in no probs in five years.any time served welder would just laugh at that comment.you may need to heat and straighten the arm after welding though.one thing to be aware of is that a lot of people like to mig weld vertical to get a neat finish but you risk getting cold overlap doing that which will introduce a weak point.
  • 4 weeks later...
Hi Suzuki
Hi Suzuki 250
What width and length did you lengthen the swing arm by because i am thinking of getting my swing arm altered?
Cheers Sam
  • 4 weeks later...
I lengthened mine by 1.5" and it still turns great. I used to feel it wheelied too easily up steel hills and it seems to grip better with the longer arm. Used a scarf cut for strength and inserted a tube for strength - used for 2 years and lots of drop offs/rocky sections and no problems.
Stu
