yamty Posted June 15, 2012 Report Share Posted June 15, 2012 I recently purchased a used full clutch kit from ebay as my clutch boss was damaged it all seemed in good condition but now that i have assembled it the clutch is slipping so bad the bike can only just pull away. does anyone know what the problem could be? Cheers Lewis Quote Link to comment Share on other sites More sharing options...
jse Posted June 15, 2012 Report Share Posted June 15, 2012 First guess. It's been a long time since I worked with the Mono clutches, but in section 3-19 of the owner's manual (for the 350 anyway), it shows an adjustment in the center of the pressure plate that may need to be reset, ie backed out a little. I'd start there first. There may be a specification in the manual as to how to measure the clutch plates for wear and the number of plates in the pack just to be sure everything is good to start with. Jon Quote Link to comment Share on other sites More sharing options...
yamty Posted June 15, 2012 Author Report Share Posted June 15, 2012 ye i had the center adjustment set to how it says in the manual, and im pretty sure all the plates are there. so i cant think what else to check the plates looked as though they had a bit of wear left in them. Cheers Quote Link to comment Share on other sites More sharing options...
jse Posted June 15, 2012 Report Share Posted June 15, 2012 T think there are alignment marks on the pressure plate and center hub, did you make sure they were together? Jon Quote Link to comment Share on other sites More sharing options...
yamty Posted June 15, 2012 Author Report Share Posted June 15, 2012 aye got them lined up thanks. think ill need to take it apart again to check i haven't done something silly. Cheers Quote Link to comment Share on other sites More sharing options...
jse Posted June 15, 2012 Report Share Posted June 15, 2012 It sounds like you've covered the major things, I agree, you may have to go back and reverse engineer the assembly to see if theres a small issue somewhere. Those clutches were designed for the big-bore MX engine and they don't usually slip unless theres a problem. Good luck! Jon Quote Link to comment Share on other sites More sharing options...
guy53 Posted June 15, 2012 Report Share Posted June 15, 2012 Cable Cable Cable . It seem's silly but I had the same problem I quadruple check everything untill someone mentionned the cable. When removed from the bike it look ok but it would'nt slide all the way.So I was burn one time now it's the first thing I check. Guy Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 16, 2012 Report Share Posted June 16, 2012 Maybe the washers. Double check a parts diagram. Quote Link to comment Share on other sites More sharing options...
handsome_al Posted June 19, 2012 Report Share Posted June 19, 2012 yamty .................. when you say "the center adjustment set to how it says in the manual" did you mean the pushrod/ball adjuster? Last time I did mine, I had to push the lever hard (to keep it line-up with the case mark) while adjusting the pushrod screw. I assume that the ball / rod / lever-arm are not worn in any way? If yours is like mine then it's a very fine line between bite or slip. Good luck Alan Quote Link to comment Share on other sites More sharing options...
yamty Posted June 19, 2012 Author Report Share Posted June 19, 2012 it turned out that the springs i had in it were too weak, i put some other ones i had in and its now working much better. i think the springs iv got in it now are maybe off a mx bike. thanks for all your advice. Quote Link to comment Share on other sites More sharing options...
