26 Mm Oko Carb
villiersprodigy
Hi does any one know what the settings are required for a 26 mm flat slide carb on a 315. A friend as let me borrow one to try to see the difference in performance against the standard dellorto carb.
As the OKO is simply a Kiehin copy in 26mm version, I would think the base settings for the Kiehin should apply directly to this application.
45 pilot, 125 main
JJH needle in mid clip position
This should give you a good start if you are reasonably close to this and you might need to refine a bit from there.
Hope that helps!
