maddog Posted June 15, 2012 Report Share Posted June 15, 2012 does anyone know the correct spark plug i need for my 92 aprilia 280 climber? been told its a bp6evx? can i use the standard bp6es plug if this is the coeect one? its currently got a bp7es plug in it an d will not run properly without being on choke. will an incorrect plug cause this problem or do i have an air leak somewhere????????? Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 16, 2012 Report Share Posted June 16, 2012 Yes, put a new plug in. A bp?es whatever will work. Your problem is still more likely the carb. Unless you have an air leak or a worn out motor. Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 16, 2012 Report Share Posted June 16, 2012 By the way post in the correct forum under bikes/ Aprilia that is the only way one of us can keep on finding the thread to help! Quote Link to comment Share on other sites More sharing options...
pindie Posted June 16, 2012 Report Share Posted June 16, 2012 Sounds like a carb issue to like a blocked pilot jet. A new plug always helps but if it needs the etc fuel by adding choke then it is not getting the right amount fuel in the first place. Blow out all carb components with compressed air. Quote Link to comment Share on other sites More sharing options...
maddog Posted June 16, 2012 Author Report Share Posted June 16, 2012 have changed the plug and cleaned and oiled the airfilter as it was manky and now it runs like a dream. ticks over and runs perfect off choke with no probs Quote Link to comment Share on other sites More sharing options...
pindie Posted June 16, 2012 Report Share Posted June 16, 2012 A ha. Classic case of maintenance. Good stuff Quote Link to comment Share on other sites More sharing options...
