clay Posted June 17, 2012 Report Share Posted June 17, 2012 Hi looking for some help with the refitment of my 315 clutch plates, I know i have to alternate between the friction plates with the steel plates, But the cofusion starts with the diffrents between the cork type plates and the paper type,,,,Is there a correct procedure,,, do you use all the cork type first, and finish with the paper type? or mix them up? Thanks in advance, clay Quote Link to comment Share on other sites More sharing options...
naichuff Posted June 17, 2012 Report Share Posted June 17, 2012 Quote from a 99 cota 315 manual Coat the clutch plates with transmission oil Install the four cork mold friction discs and clutchplates aternately Install the three paper mold friction discs and clutch plates alternately starting with a clutch plate. Quote Link to comment Share on other sites More sharing options...
clay Posted June 18, 2012 Author Report Share Posted June 18, 2012 Naichuff, your a lifesaver, thanks again,,, Quote Link to comment Share on other sites More sharing options...
