315 Clutch Refitment Help
clay
Hi looking for some help with the refitment of my 315 clutch plates,
I know i have to alternate between the friction plates with the steel plates, But the cofusion starts with the diffrents between the cork type plates and the paper type,,,,Is there a correct procedure,,, do you use all the cork type first, and finish with the paper type? or mix them up? Thanks in advance, clay
Quote from a 99 cota 315 manual Coat the clutch plates with transmission oil
Install the four cork mold friction discs and clutchplates aternately
Install the three paper mold friction discs and clutch plates alternately starting with a clutch plate.
