yamty Posted June 20, 2012 Report Share Posted June 20, 2012 after getting my clutch fixed i took the bike out for a run and then one of the forks seized solid. it does move a little while twisting it but it feels very rough, i don't know how im going to get it apart. iv been meaning to change the seals for a while as they were leaking very badly so i suspect the lack of oil is what caused it to seize. does anyone know how ill be able to get it apart. i just hope this hasn't caused any serious damage. Cheers Lewis Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 20, 2012 Report Share Posted June 20, 2012 To much oil will also cause the forks to lose movement, personally I would take out the drain screws and pump them to see what, if anything, comes out. Quote Link to comment Share on other sites More sharing options...
yamty Posted June 20, 2012 Author Report Share Posted June 20, 2012 iv taken them of and there is very little oil in them. but i cant pump one of them because its seized. Cheers Quote Link to comment Share on other sites More sharing options...
jse Posted June 21, 2012 Report Share Posted June 21, 2012 Is the fork stuck at full extention or partially compressed? If partially compressed, the upper tube may be bent. If at extention, the bushings, or possibly the damper rod may be the problem. I'd try taking the base bolt out (it's at the bottom of the lower leg and then take the seal circlip out and use a little heat on the top of the lower leg to see if that eases it out. Jon Quote Link to comment Share on other sites More sharing options...
