reginald Posted June 23, 2012 Report Share Posted June 23, 2012 Hi Guys, the story is all here http://www.trials.com.au/forum/viewtopic.php?f=16&t=7485 Latest theory is disk valve jumping spline or cracking any thoughts or theories appreciated. Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 23, 2012 Report Share Posted June 23, 2012 If you have checked points and condensor, swap coil, then stator. Some ignition problems sound/feel like carb/fuel. Quote Link to comment Share on other sites More sharing options...
reginald Posted June 23, 2012 Author Report Share Posted June 23, 2012 Thanks B40rt will swap condenser then others. It is a new one ...... Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted June 23, 2012 Report Share Posted June 23, 2012 Certainly I recall a pal had the disc valve "jump the splines" back in the day so it can happen and, presumably, is easily checked? Quote Link to comment Share on other sites More sharing options...
reginald Posted June 23, 2012 Author Report Share Posted June 23, 2012 Condenser replaced - sweet as a nut. Thanks to all the people that gave hints. That condenser was only a few hours old so it was not up there on the things to change first.... Quote Link to comment Share on other sites More sharing options...
