smallboy Posted June 25, 2012 Report Share Posted June 25, 2012 Hi What are the cosmetic differences between a 2010 and a 2011 GAS GAS 250,please advise as do not know the differences. Cheers David Quote Link to comment Share on other sites More sharing options...
gasthatchgas Posted June 25, 2012 Report Share Posted June 25, 2012 Main difference is the change in the frame shape and geometery. Also tail pipe is different style and re-designed airbox Quote Link to comment Share on other sites More sharing options...
telecat Posted June 25, 2012 Report Share Posted June 25, 2012 That's it in a nutshell. In detail the Airbox is bigger and opens from the front not the back. It's easier to seal and the opening is bigger as well so it's easier to get at the filter. The frame on the 2011 has a triangle section around the airbox to strengthen it. It also allows better "breathing" as the gaps for the airflow are bigger. The Exhaust is a bit more rugged and the new back section makes it easier to get at the baffle. Quote Link to comment Share on other sites More sharing options...
laser1 Posted June 26, 2012 Report Share Posted June 26, 2012 As I recall, the 2011 rear wheel is D.I.D. style as well - no rim band. I think. Quote Link to comment Share on other sites More sharing options...
telecat Posted June 26, 2012 Report Share Posted June 26, 2012 As I recall, the 2011 rear wheel is D.I.D. style as well - no rim band. I think. Yep works really well. I bought a DID a couple of years ago so forgot this. Still will not stop some tyres going down but they stay pressured longer. Quote Link to comment Share on other sites More sharing options...
