penno350 Posted July 2, 2012 Report Share Posted July 2, 2012 Is there any type of Sherpa footrest mod that doesn't involve welding new brackets or mountings? Quote Link to comment Share on other sites More sharing options...
woody Posted July 3, 2012 Report Share Posted July 3, 2012 (edited) What I did with a Pursang a few years back was to cut a pair of Bultaco rests in half and weld the half that bolts to the frame lug onto a Honda (or whatever) motocross footrest. This gave a modern wider rest which bolted to the existing frame lug. It was the best option I found for better footrests if you aren't bothered about moving their location. Used M/X footrests should be plentiful and cheap on ebay - They're usually steel off the older bikes. Edited July 3, 2012 by woody Quote Link to comment Share on other sites More sharing options...
penno350 Posted July 3, 2012 Author Report Share Posted July 3, 2012 Cheers Woody, that's where my thinking was going as I don't want to change the frame from original if I can avoid it. Quote Link to comment Share on other sites More sharing options...
steamsh1p Posted July 4, 2012 Report Share Posted July 4, 2012 Hi Guys, Newbie here, i purchased Frontera footpegs which are approx 1 1/4" longer same pattern and bolt straight on. i got mine from Bultaco UK, and they work great. Quote Link to comment Share on other sites More sharing options...
