348 Stuck Fork Leg
petenz
just started the build on my 348 ,,
the right fork leg is stuck 3/4 of the
way though it's travel... " locked solid"
spring out bottom bolt out theres no
way this thing will move.. A bent main
is a possability but the top section looks
stright so if there is a bend it's down in the
botton slider...
Any other ideas what could be the prob if
its not a bent main tube & how to get it apart ?
Edited by petenz
Pete is it rusty in there? I had problems with getting some 348 forks apart when there was rust blisters on the inside surface of the tube
from what tube is out of the slider theres is no visable rust other than very small
pits under where the plastic sleeves were between the triple clamps..
the other leg shows no sign of rust...
I mean rust inside the tubes where the piston contacts the tube
Ok..not looked to hard in there..
if the bottom bolt holding the
damping rods removed wouldn't
the stachon/damping rod/piston
all slide out as a unit if theres rust
stoping the piston moveing inside
the stanchon ?
could you clamp an old yoke to it and use that to hammer it out or try and turn it with wd40 in there
What I will try.. Is clamp the stanction in the lathe chuck to hold it , put the axle bolt though
the slider axle hole see if I can rotate it while pulling..
hammering it will be the last option..
Edit.... I got it... twist pull it came out .. couldn't see anything wrong..
now it slides like it never had a prob..damping rod pushed out easy..
I have no idea what the prob was... No dents or bends...
just struck another issue while pulling it apart..can't get the swing arm
pivit bolt out.. must be rusted in...Get the motor out and cut though the bolt
& bushs each side... then turn up some new bushs/internal sleeve & bolt...
Edited by petenz
Pete, the older Montesa forks will stick if the bike sits unused for a period of time. Dissimilar metals reaction may be the cause. I have found this in many old Montesas. Some cases are worse than others. Time is the main factor. Sometimes all the piston needs is a light sanding. I have seen others that required new psitons.
My method of removal is to drive them out with a wooden broomstick and mallet.
Found the prob..
Alloy piston on the top of the damping
rod has cracked in two..was cleaning it
up and fell on the floor in two...
So I will turn up 2 new ones in Acetal "nylon"
theres no load on them spring pressure is
on the damping rod..
