petenz Posted July 5, 2012 Report Share Posted July 5, 2012 (edited) just started the build on my 348 ,, the right fork leg is stuck 3/4 of the way though it's travel... " locked solid" spring out bottom bolt out theres no way this thing will move.. A bent main is a possability but the top section looks stright so if there is a bend it's down in the botton slider... Any other ideas what could be the prob if its not a bent main tube & how to get it apart ? Edited July 5, 2012 by petenz Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 5, 2012 Report Share Posted July 5, 2012 Pete is it rusty in there? I had problems with getting some 348 forks apart when there was rust blisters on the inside surface of the tube Quote Link to comment Share on other sites More sharing options...
petenz Posted July 5, 2012 Author Report Share Posted July 5, 2012 Pete is it rusty in there? I had problems with getting some 348 forks apart when there was rust blisters on the inside surface of the tube from what tube is out of the slider theres is no visable rust other than very small pits under where the plastic sleeves were between the triple clamps.. the other leg shows no sign of rust... Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 5, 2012 Report Share Posted July 5, 2012 I mean rust inside the tubes where the piston contacts the tube Quote Link to comment Share on other sites More sharing options...
petenz Posted July 5, 2012 Author Report Share Posted July 5, 2012 I mean rust inside the tubes where the piston contacts the tube Ok..not looked to hard in there.. if the bottom bolt holding the damping rods removed wouldn't the stachon/damping rod/piston all slide out as a unit if theres rust stoping the piston moveing inside the stanchon ? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 5, 2012 Report Share Posted July 5, 2012 Yes you are right. More thinking needed. Ah heres a thought, maybe there is a dent in the slider? Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted July 5, 2012 Report Share Posted July 5, 2012 Yes you are right. More thinking needed. Ah heres a thought, maybe there is a dent in the slider? could you clamp an old yoke to it and use that to hammer it out or try and turn it with wd40 in there Quote Link to comment Share on other sites More sharing options...
petenz Posted July 5, 2012 Author Report Share Posted July 5, 2012 (edited) could you clamp an old yoke to it and use that to hammer it out or try and turn it with wd40 in there What I will try.. Is clamp the stanction in the lathe chuck to hold it , put the axle bolt though the slider axle hole see if I can rotate it while pulling.. hammering it will be the last option.. Edit.... I got it... twist pull it came out .. couldn't see anything wrong.. now it slides like it never had a prob..damping rod pushed out easy.. I have no idea what the prob was... No dents or bends... just struck another issue while pulling it apart..can't get the swing arm pivit bolt out.. must be rusted in...Get the motor out and cut though the bolt & bushs each side... then turn up some new bushs/internal sleeve & bolt... Edited July 6, 2012 by petenz Quote Link to comment Share on other sites More sharing options...
martin belair Posted July 6, 2012 Report Share Posted July 6, 2012 Pete, the older Montesa forks will stick if the bike sits unused for a period of time. Dissimilar metals reaction may be the cause. I have found this in many old Montesas. Some cases are worse than others. Time is the main factor. Sometimes all the piston needs is a light sanding. I have seen others that required new psitons. My method of removal is to drive them out with a wooden broomstick and mallet. Quote Link to comment Share on other sites More sharing options...
petenz Posted July 9, 2012 Author Report Share Posted July 9, 2012 Found the prob.. Alloy piston on the top of the damping rod has cracked in two..was cleaning it up and fell on the floor in two... So I will turn up 2 new ones in Acetal "nylon" theres no load on them spring pressure is on the damping rod.. Quote Link to comment Share on other sites More sharing options...
