4t Sherco
dixie
Anyone got or riding a 4t sherco,
Do you ever use the choke ?
Mine seems to start first or second kick without it from dead cold,on the couple of occasions i have used it it flooded.
turned it off and a couple of kicks and it fires up no problem ?
Is this because the weather is warm ?
When it is running it seems fine and just keps getting better
Mine burnt a bit of oil for the first couple of hours only a puff
the motor is just getting stronger and stronger;
four strokes get a bit of upper cylinder lube from oil left in the bore and through the valve bushes ,
the sherco definitly has the edge over the mont on bottom end ,it is a real tractor off the bottom,cant wait to give it some
  • 3 weeks later...
Dixie,
recieved my 4T last week. Yes, i need the choke on to start it, also
needs to be left on for a minute or so.
Engine dies if i take the choke off too soon.
Obviously choke not need when warm.
